Devices Smart Business Connect
Overview
Modern fixed telephone from one source:
  • Most existing analogue phones can continue to be used; however the keypad must include the * and # keys.
  • Dial-operated phones are no longer supported; if you still wish to use a dial-operated phone, you will need a pulse dial to DTMF adapter. This is not supplied by Swisscom. Please note that Swisscom cannot guarantee the function of this special application.
  • Use the business communication app to make calls even when you are not in the office. Do so with your fixed-network business number via your mobile phone or PC.
  • You can do more than just make calls with the communication package which includes UCC functions. Use the new communication options like instant messaging (chat), screen sharing, presence status, online meetings and guest access to collaborate with colleagues, customers and partners even more efficiently. You can access the business communication app either in- or out-of-office.
IP telephones
With IP telephones, enjoy all the benefits of modern landline telephony. The following IP telephones can be used with Smart Business Connect. We have tested a wide range of IP telephones and approved them for Business Communication. The following IP telephones can be obtained through your partner:
Mitel
Mitel 6863
Mitel 6865
Mitel 6867
Mitel 6869
Yealink
Yealink T42G
Yealink T46G
Yealink T48G
Yealink CP860
Panasonic Multi Cell
Panasonic
UDT111
Panasonic
UDT121
Panasonic
UDT131
Panasonic Mulitcell UDS124
Panasonic Single Cell
Panasonic KX-TGP600
Customer Center
