Cancelling or putting services on hold
Cancel subscription
Contact us if you would like to cancel your mobile subscription, fixed network, TV or Internet services.
If you wish to withdraw from the contract outside the regular termination period, you will normally be charged for the outstanding instalments up to the minimum contract period.
Note: You can also put your mobile contract on hold. Instead of cancelling your contract and losing your mobile number, you can put your contract on hold for up to 12 months. You can then reactivate the subscription and use the same telephone number again.
Costs in case of an early subscription change
If you would like to change your mobile subscription to a lower subscription fee within the first 12 months after signing or extending the contract, you will be charged a one-off fee of CHF 300. It does not matter whether you have purchased a device at a reduced subscription price or not. After the first 12 months, a change of subscription does not result in any costs.
Suspending mobile subscriptions
If you don’t need your mobile subscription for a while, for instance if you plan to go abroad for a lengthy stay, you can put your contract on hold. The suspension period can be between two and 12 months. You won't be charged any monthly fees during this period. After reactivation you can use the same telephone number again.
You can easily set up temporary subscription suspension in the Customer Center.
Requirements
  • You cannot put your mobile subscription on hold if you are still paying mobile phone instalments. If you still wish to put your contract on hold, you need to settle any outstanding device instalments in the Customer Center first.
  • You can only put your subscription on hold once during the minimum contractual term.
You cannot put fixed network, TV and Internet subscriptions on hold; the option is not available for DSL and Natel®Pro either.
Cost and time period
  • A one-off fee of CHF 25.– is charged for suspension.
  • You do not pay any monthly subscription fees during suspension.
  • The minimum contract period is extended by the respective number of months.
  • On expiry of the minimum contractual term, you can change to a lower cost subscription or Prepaid as an alternative to temporary suspension. Please note, however, that you must make one call a year for Prepaid.
 Support
Contact
Do you have questions concerning our products?
We will help you via telephone or chat.
Related help topics
