Returning equipment
On this page:
Return ordered items, devices, Internet and TV-Boxes and select return option.
Return item
Should an ordered item fail to meet your requirements, you can send it back within 14 days free of charge. Place the item in the original packaging and print the return slip in the Customer Center.
If you receive a faulty item, please return the product you ordered as soon as possible using the return slip from the Customer Center.
Return Internet and TV-Boxes
Internet-Box
If you no longer need your Internet-Box, you are welcome to return it to Swisscom. Depending on the model and condition of the Internet-Box, it will either be refurbished for another customer as a replacement device or properly disposed of. We will of course delete all of your customer data. Your Internet-Box can be returned via one of over 800 Päckli Punkt locations, by post or by using the pick@home service.
Swisscom TV-Box
If you have a second-generation Swisscom TV-Box (HD), it is not your property. If you no longer need it, you must return it to Swisscom. Your TV-Box can be returned via one of over 800 Päckli Punkt locations, by post or by using the pick@home service. If you have purchased a latest-generation Swisscom TV-Box (UHD), it belongs to you. If you no longer require it, you can return it if you prefer. Swisscom can refurbish the TV Box and give it to another customer as a replacement device. If you no longer require a first-generation Swisscom TV-Box you can also choose whether you want to keep it or return it to Swisscom.
Returning your old mobile phone
If you have an old mobile phone at home that you no longer need, you can return this to a Swisscom Shop. Either sell it through Swisscom Buyback or donate it through Swisscom Mobile Aid.
Return Internet-Booster
If you no longer wish to use your Internet-Booster, please return it free of charge via one of 800 Päckli Punkt locations, by post or via pick@home. This will give someone else the chance to enjoy faster Internet at home
Ways to return
Päckli Punkt
Items that you have ordered or devices you no longer need can be returned free of charge at one of over 800 Päckli Punkt locations in Switzerland, allowing you to take advantage of extended opening hours. You can return your package in the evening, at the weekend or on public holidays at selected locations.
To return an ordered item: Download the return slip from the Customer Center. Cut out the return label, stick it to the package and enclose the return slip with the package. You do not need to use a return slip if you no longer require an older device. Then take the package to one of the following Päckli Punkt locations in your area:
Swiss Post
You may also return the items you have ordered free of charge by post. Proceed as follows:
Ihre bestellten Artikel können Sie selbstverständlich auch per Post kostenlos zurücksenden. Gehen Sie dazu wie folgt vor:
  1. Place the goods in the original packaging.
  2. Download the return slip from the Customer Center.
  3. Cut out the return label, stick it to the package and enclose the return slip with the package.
  4. Return the equipment that is no longer needed to us by post.
  5. Obtain a receipt for the return.
pick@home
Would you like us to collect your returns from your home or another address, such as the office? Then use the pick@home service, which is provided to you free of charge by Swiss Post.
Click the following consignment number corresponding to your return slip (you will find this in the Customer Center) and register your collection request with pick@home.
Consignment numbers beginning with 99.60.012750
Consignment numbers beginning with 99.34.147462
Möchten Sie Ihre Rücksendungen zu Hause oder an einer anderen Adresse, z.B. im Büro, abholen lassen? Dann nutzen Sie den für Sie kostenlose Dienst pick@home der Post.
Klicken Sie auf die folgende Sendungsnummer, welche Ihrem Rücksendeformular entspricht und melden Sie Ihren Abholwunsch bei pick@home an.
Sendungsnummer beginnend mit 99.60.012750
Sendungsnummer beginnend mit 99.34.147462
  1. Select your preferred collection date and place.
  1. Enter the shipment number from the return label.
  2. Cut out the return label, stick it to the package and enclose the return slip with the package.
  3. We will send you an order confirmation by e-mail or SMS.
 Support
Contact
Do you have questions concerning our products?
We will help you via telephone or chat.
Related help topics
