TV-Box  (HD)
On this page:
Get information about the TV-Box (HD) ports and setup instructions. You will also find out how to return your old TV-Box.
Installation and connections
Download the instruction PDF to get more information about the connections and buttons of the TV-Box (HD)
Internet Box Light
Set up and use
Help topics & tips TV-Box (HD)
Instruction and energy consumption
Frequently asked questions
LED lights up white: the TV-Box is switched on.
LED lights up red: the TV-Box is on standby, or has no Internet connection
LED does not light up: the TV-Box is switched of
The TV-Boxes can be connected with all Swisscom routers. With one restriction: the Voice Assistant cannot be used with the Centro Business router.
Yes, each household can use up to 5 TV-Boxes. You can use any TV-Boxes. However, please note the device restrictions.
Yes, you can also use Blue-TV without a Swisscom TV-Box. Find out more about using blue TV in the browser, via the app or with a third-party provider.
The TV-Box belongs to you and you are under no obligation to return it to Swisscom. However, if you no longer need the TV-Box, Swisscom can refurbish it and give it to another customer as a replacement device.
Find out more
Help from the Swisscom Community
Couldn't find an answer? Ask the Swisscom Community. More than 10,000 active users are waiting to help you.
