Updating firmware
Your router firmware
Swisscom regularly updates the Centro Business 2.0 firmware so you continue to benefit from new functions and improvements after purchase. Updates are automatic, usually at night.
We call the software which provides all the Centro Business 2.0 functions firmware. This web page provides details of the current firmware versions, improvements and new functions.
Latest firmware for Centro Business 2.0 (January 2020)
9.04.10
Installation
If you do not want to wait until your router is upgraded, you can also download and install the firmware manually.
Firmware update via the router portal (recommended)
  1. Connect your router by means of an Ethernet cable and open the router portal by entering the URL 192.168.1.1 in your browser
  2. You can find the latest firmware release under the menu item Settings --> Router --> Firmware
  3. Search for the latest firmware release (see item 1 of the figure)
  4. Update the firmware if your existing release is not up to date (see item 2 of the figure)
Toolkit for Business
Firmware for "Toolkit for Business" users
Swisscom regularly updates the Centro Business firmware so you continue to benefit from new functions and improvements after purchase. Updates are automatic, usually at night.
We call the software which provides all the Centro Business functions firmware. This web page provides details of the current firmware versions, improvements and new functions.
Latest firmware for Centro Business (Octobre 2020)
7.12.16 sig
All Centro Business will be automatically updated to the new version in the next few weeks.
Installation
Firmware update via the router portal (recommended):
Release notes of older firmware versions
Router Firmware 7.12.12 sig (Octobre 2019)
Router Firmware 7.12.10 sig (September 2017)
Router Firmware 7.10.18 sig (November 2016)
Please use the following online form for suggestions or improvements to the current firmware
In case of problems or support requests please contact us.
