Find out everything you need to know about the operation and functions of this HD phone.
The HD-Phone Arosa only works in conjunction with the Swisscom Internet-Box on a fixed network connection (IP).
Download here the PDF version. (PDF file, 828 KB)
Download here the PDF version. (PDF file, 141 KB)
Download here the PDF version. (PDF file, 30 KB)
Your Arosa HD-Phone has a choice of 10 ringtones. You can select different ringtones for internal and external calls.
Change settings directly on your handset:
You can now listen to all the available ringtones and save your favourite one.
You can assign a different ringtone for every directory entry so you can recognise when a family member is calling by the ringtone, for instance.
On your handset, press Menu > Directory > Add and select the required ringtone via the note icon.
