Customer Center E-Mail + SMS TV myCloud Find a Swisscom shop Contact
Davos HD-Phone
On this page:
Install your Davos HD-Phone, change the battery, activate the crown button and set up additional functions.
Installation & keypad overview
Find out everything you need to know about using the new HD phone and its functions.
The Davos HD-Phone only works in conjunction with the Swisscom Internet-Box on a fixed network connection (IP).
Instructions
Set up
Making calls
Managing calls
Replacing the battery
  1. Pick up the telephone. Press hard on the cover with both thumbs and push it away from you at the same time.
  2. Replace the batteries. Only use AAA NiMH-930 mAh batteries.
  3. Replace the cover on the telephone and close the battery compartment by pushing the cover back until it snaps into place (clicks).
Crown button
The crown button can be assigned a function of your choice. The following options are available:
  • Display missed calls
  • Make an internal call
  • Select a saved number using the direct call function
  • Add the last number to the blacklist
  • Block incoming calls
  • Block anonymous calls
  • Deflect calls
  • Withhold your number
How to activate the crown button: Press Menu > Settings > on your handset, configure the crown button and select the function of your choice.
Please note: If you block incoming calls via the crown button you can only reverse this setting in the Swisscom customer center.
Video instructions on the crown button.
More functions
Change ringtone
Speed dial
Clock and alarm
Babyphone
Night mode
