On this page:
Find out more about the operation, keys and functions of the Montreux HD-Phone and how to set it up and use it.
Find out about the device and the HD-Phone buttons in the button overview. The Montreux HD-Phone only works in conjunction with the Swisscom Internet-Box on a fixed network connection (IP).
In diesem Video zeigt Oliver, Trainer bei Swisscom Academy, den Lieferumfang der Internet-Box 4 und erklärt dir wie man diese Installiert.
Before you press the + key (pairing key/connection key) on the Internet-Box (base station), start the automatic DECT registration process as follows:
The crown button can be assigned a function of your choice. The following options are available:
How to activate the crown button: On your handset press Menu > Settings > Configure crown button and select the function of your choice.
Please note: If you block incoming calls via the crown button you can only reverse this setting on
My Swisscom (Customer Center)(opens in new tab).
Your HD-Phone Montreux has a choice of 14 ringtones in premium HD quality. You can select different ringtones for internal and external calls.
Change settings directly on your handset:
You can now listen to all the available ringtones and save your favourite one.
You can allocate your important telephone numbers to numbers 0 and 2 to 9 (e.g. the internal number of an additional handset, a contact from the phone book or a number you enter manually).
To retrieve the phone number later, press the programmed number and hold it down.
