On this page:
Find out more about the operation, keys and functions of the Zermatt HD-Phone and how to set it up and use it.
Find out about the device and the HD-Phone buttons in the button overview. The Zermatt HD-Phone only works in conjunction with the Swisscom Internet-Box on a fixed network connection (IP).
In diesem Video zeigt Oliver, Trainer bei Swisscom Academy, den Lieferumfang der Internet-Box 4 und erklärt dir wie man diese Installiert.
Before you press the + key (pairing key/connection key) on the Internet-Box (base station), start the automatic DECT registration process as follows:
The crown button can be assigned a function of your choice. The following options are available:
How to activate the crown button: On your handset press Menu > Settings > Configure crown button and select the function of your choice.
Please note: If you block incoming calls via the crown button you can only reverse this setting on My Swisscom (Customer Center)(opens in new tab).
Your Zermatt HD-Phone has a choice of 20 ringtones in premium HD quality. You can select different ringtones for internal and external calls.
Change settings directly on your handset:
You can now listen to all the available ringtones and save your favourite one.
You can allocate your important telephone numbers to numbers 0 to 9 (e.g. the internal number of an additional handset, a contact from the phone book or a number you enter manually).
To retrieve the phone number later, press the programmed number and hold it down.
When the clock is activated it displays the time and date on the handset when it rests on the charger and is not in use. If you do not wish to have this function, you can switch it off.
Proceed as follows:
You have the option to set an alarm on your HD-Phone.
Change the settings as follows:
When the alarm rings you can stop it by pressing the off (left) button. Every time you press the snooze option (right button or any other button) the alarm will ring again in another five minutes.
If the alarm is not switched off, it will stop automatically after 10 minutes.
Your HD-Phone can also work as a babyphone. Activate the babyphone function and enter a phone number (e.g. your mobile number) as the recipient.
The recipient's phone rings as soon as the baby makes a noise. When you activate the function, you can set whether you want the HD-Phone to ring at low noise levels (high sensitivity) or only respond to louder baby noises (low sensitivity). Place the HD-Phone around 1-2 metres away from your baby and point the microphone at the baby. The HD-Phone will not receive calls while the babyphone function is active.
Change the following settings to activate the babyphone:
You can select night mode to change your handset’s settings for a specific time. The following options are available:
