Yealink T46G HD-Phone
On this page:
Install and operate your Yealink T46G HD-Phone.
Installation & keypad overview
Find out everything you need to know about the operation and functions of this HD phone.
Residential customers need an Internet-Box or Centro grande and fixed-line access (IP) to use the Yealink T46G.
Business customers need the Centro Business and fixed-line access (IP) to use fixed-line telephony.
Instructions
Making calls
Managing calls
Setup
Setting up your Yealink T46G HD-Phone:
  1. Plug the telephone cable supplied into the receiver and the socket with the receiver symbol on the base of the telephone.
  2. Plug the network cable supplied into the Internet socket on the base of your telephone and into one of the network (LAN) ports on the router you are using.
  3. Connect the power cable to the base of the telephone and plug the other end of the power cable into a conventional socket.
  4. Follow the instructions on the display.
