QBee Multi-Sensor Kamera
QBee multi-sensor camera
The QBee Camera is a multi-sensor indoor HD IP Camera with night vision that also detects movement and measures temperature, humidity and brightness.
The camera is simple to install and easy to use.It is compatible with Internet-Box 2, plus and standard.
Do I need a QBee- account to use the camera in the Internet-Box app?
Operation tips & short cuts
Camera function overview
How does motion detection work?
Recording limit and storage location
What is privacy mode on the QBee camera and how can I switch it on?
Why did I receive a "Camera surveillance "sticker?
