Universal wireless connection kits
Universal wireless connection kits DUO & UNO
Wireless connection from the location of the router to another room for up to 4 devices.
Installation instructions
DUO
(starter-kit)
manual duo
UNO
(extension kit)
manual uno
The universal connection kits in use:
Universal wireless connection kit FAQs
Can I connect my Wi-Fi computer to the universal connection kit Wi-Fi?
What is the difference between the UNO and the DUO universal connection kits?
Why can't I use Wi-Fi from a router and then send the signal to a UNO device?
Can I watch HD broadcasts on Swisscom TV while the universal connection kit is in use?
The LED connection indicator is red, but I can still watch TV. What should I do?
Are the universal connection kits compatible with the previous model (black kits)?
What are the technical specifications and capacities of the universal connection kits?
