Customer Center E-Mail + SMS TV myCloud Find a Swisscom shop Contact
Swisscom TV remote control
On this page:
Functions, user manuals, help with replacing batteries and solutions for function problems with the Swisscom TV remote control.
Functions
To get more information about the buttons on your remote, click on the blue plus in the picture.
Replacing your remote control
If your remote control is faulty (damage caused by dropping etc.), please contact our customer service. You cannot purchase a remote control in the Swisscom Shop or the Swisscom Online Shop.
LED lights up/no response
The LED on the remote control usually lights up white when you press a button.
Flashing red 5 times
The TV-Box is not within range of the remote control. Move closer to the TV-Box.
The TV-Box does not have power. Check if the TV-Box is plugged into a socket.
The TV-Box needs to be rebooted for technical reasons. Reboot the TV-Box.
LED is red when you press a button
The remote control is not connected to the TV-Box.  Reconnect the remote control to the TV-Box.
LED is red every tenth time you press a button
  Lights up white permanently
No LED/remote control does not respond
The batteries are (almost) done.  Change the remote control batteries.
Your remote control is also available as an app
Use your smartphone as a remote control with the TV Air app remote control function. You can find the remote control under "Home", at the top right.
Change batteries
Put your thumb on the gap
Push the cover away from you with light pressure
Insert the batteries
Pair remote control
  • Press the OK button on your Swisscom TV remote
    Turn off your TV Box with the flip switch on the back and turn it on again after a few seconds.
  • If the remote control still isn't working, reconnect the TV B ox to the Swisscom TV remote control:
    Press the TV Box's WPS button for 3 seconds and then release it.
    As soon as this screen appears on your TV, press the OK button on the Swisscom TV remote control.
    The LED will now blink white until the remote control is connected.
 Support
Contact
Do you have questions concerning our products?
We will help you via telephone or chat.
Related help topics
