Updating firmware
Which Internet-Box are you using?
Updating firmware
Swisscom regularly updates the WLAN-Box with the latest firmware so you continue to benefit from new functions and improvements after purchase. Updates are automatic, usually at night.
We call the software which provides all the WLAN-Box functions firmware. This web page provides details of the current firmware versions, improvements, and new functions.
Current firmware for WLAN-Box (february 2019)
10.01.29
All WLAN-Boxes will be automatically updated to the new version in the upcoming weeks.
Currently installed firmware version
You can check which firmware version is currently installed on your Internet-Box on the Internet-Box web portal at any time. Select “Expert mode” and click on “Internet-Box” > “Firmware” on the menu. Please note that you only have access to the web portal when your home network is connected to your Internet-Box.
Installation
If you don’t want to wait until your WLAN-Box is updated automatically, you can download and install firmware manually.
  1. Download the latest firmware version
  2. Open the Internet-Box web portal at http://internetbox.home. Please note that you only have access when your home network is connected to your Internet-Box.
  3. Switch to “Expert mode”.
  4. Look up the IP address for your WLAN-Box in the “Network, device list” menu (usually an address between 192.168.1.100 – 160).
  5. Open the WLAN-Box web portal via http://192.168.1.xyz (the IP address which you looked up in the device list in the previous step).
  6. Click the “WLAN-Box” option in the WLAN-Box main menu.
  7. Now select the locally stored firmware file and launch the update.
Release notes for older firmware versions
Router Firmware september 2018 (10.00.33)
Router Firmware may 2018 (09.02.01)
Updating firmware
Swisscom regularly updates the Internet-Box with the latest firmware so you continue to benefit from new functions and improvements after purchase. Updates are automatic, usually at night.
We call the software which provides all the Internet-Box functions firmware. This web page provides details of the current firmware versions, improvements and new functions.
Current firmware for Internet-Box 2 (april 2019)
10.01.42
All Internet-Boxes will be automatically updated to the new version in the upcoming weeks.
Installation
If you don’t want to wait until your Internet-Box is updated automatically, you can download and install firmware manually.
  4. You will find the “Firmware page” in the “Internet-Box” menu.
  5. Now select the locally stored firmware file and launch the update.
Router Firmware february 2019 (10.01.38)
Router Firmware October 2018 (09.05.00)
Updating firmware
The Internet-Box plus is operated by two firmware packages. One package is responsible for standard router functions (connection to the Internet, WLAN, IP and telephony); the other is responsible for the additional built-in application processor. Swisscom can offer additional useful functions on this application processor without impacting on Internet performance. Swisscom currently provides the central storage function on the application part. Other functions can be added with simple firmware updates.
Current firmware for Internet-Box plus (april 2019)
10.01.42
Current application firmware for Internet-Box plus (february 2019)
10.01.50
Installation
Router Firmware february 2019 (10.01.36)
Router Firmware september 2018 (10.00.44)
Updating firmware
Current firmware for Internet-Box standard (april 2019)
10.01.42
Installation
(Release Notes) Older Firmware versions
Updating firmware
Current firmware for Internet-Box light (August 2018)
08.05.02
Installation
Router Firmware June 2018 (08.04.36)
Router Firmware November 2017 (08.04.26)
 Support
Contact
Do you have questions concerning our products?
We will help you via telephone or chat.
Related help topics
