Which WLAN-Box are you using?
Updating firmware
Swisscom regularly updates the WLAN-Box with the latest firmware so you continue to benefit from new functions and improvements after purchase. Updates are automatic, usually at night.
We call the software which provides all the WLAN-Box functions firmware. This web page provides details of the current firmware versions, improvements, and new functions.
Current firmware for WLAN-Box 2
12.00.27
12.02.21
Currently installed firmware version
You can check which firmware version is currently installed on your Internet-Box on the Internet-Box web portal at any time. Select “Expert mode” and click on “Internet-Box” > “Firmware” on the menu. Please note that you only have access to the web portal when your home network is connected to your Internet-Box.
Installation
If you don’t want to wait until your WLAN-Box is updated automatically, you can download and install firmware manually.
  1. Download the latest firmware version
  2. Open the Internet-Box web portal at http://internetbox.home. Please note that you only have access when your home network is connected to your Internet-Box.
  3. Switch to “Expert mode”.
  4. Look up the IP address for your WLAN-Box in the “Network, device list” menu (usually an address between 192.168.1.100 – 160).
  5. Open the WLAN-Box web portal via http://192.168.1.xyz (the IP address which you looked up in the device list in the previous step).
  6. Click the “WLAN-Box” option in the WLAN-Box main menu.
  7. Now select the locally stored firmware file and launch the update.
Updating firmware - WLAN-Box 2
Release notes for older firmware versions
WLAN-Box 2 Firmware April 2021 (11.03.33)
WLAN-Box 2 Firmware October 2020 (11.02.11)
WLAN-Box 2 Firmware july 2020 (11.01.25)
WLAN-Box 2 Firmware march 2020 (11.01.21)
Updating firmware
12.00.27
12.02.21
Installation
WLAN-Box Firmware April 2021 (11.03.33)
WLAN-Box Firmware October 2020 (10.05.19)
WLAN-Box Firmware March 2020 (10.04.23)
WLAN-Box Firmware November 2019 (10.03.17)
WLAN-Box Firmware july 2019 (10.02.17)
WLAN-Box Firmware february 2019 (10.01.29)
 Support
Contact
Do you have questions concerning our products?
We will help you via telephone or chat.
Related help topics
