Picture & sound problems
On this page:
Check your connection online or use our tips to solve your Swisscom TV problems.
Our recommendation
Log into the My Swisscom Customer Center and check whether there is a fault on your line. Here, you will also find step-by-step technical support.
At swisscom.ch/status and in the My Swisscom app, we will also inform you about current faults and maintenance work.
Fix problem manually
We notify you of current faults and maintenance work on our service website and via the Swisscom app.
If your Swisscom TV picture or sound is interrupted, distorted or freezes, it may be for various reasons.
The following steps may solve the problem:
  • Check the connections
    Check whether all the plugs are firmly connected to the router, the connection kits, the TV-Box and TV set. Remove and reconnect all plugs.
    Disconnect devices from the power
    Disconnect any connection kits from the power for 10 seconds; after reconnection, wait until the kit is ready for operation again. Now reboot the TV-Box and router.
  • Select the HDMI channel
    Select the HDMI channel on your TV set. Look for the right button to switch to the AV channel on your TV set remote control (not the remote control of the Swisscom TV-Box). Refer to the user guide of your TV set to see which is the right button.
    Press the TV Guide button
    Press the TV Guide button once on the remote control of your Swisscom TV-Box. It will then transmit a picture that you can immediately recognise as a Swisscom TV picture.
 Support
Contact
Do you have questions concerning our products?
We will help you via telephone or chat.
Related help topics
