Use the Replay function to view previously aired programmes and films on your Swisscom TV. You can activate and use the Replay function on your television, via the TV App on your mobile devices or in the web, provided you have one of these subscriptions:
Depending on your subscription you can view or record programmes up to seven days old.
❗ | Tip: You can see your subscription in the Customer Center. |
❗ | Note: The Replay function isn’t available if you are a business customer using TV Public. |
If you would like to use the Replay function on your smartphone, tablet or in the web browser, you can do so with TV Air, depending on your subscription.
Want to find your favourite channel quickly? Swisscom TV lets you list channels in the sequence of your choice. You can quickly set up and adjust the channel sequence in the Customer Center, in the Swisscom TV App 2.0 or on your TV set.
Log into the Kundencenter |
Select TV and Radio > Swisscom TV > Manage channels |
Give your channel list a name, e.g. “My favourite channels”. |
Activate channels and place them in the order you want via drag & drop. Once you've saved your channel list it is also available on your TV-Box. |
The TV Guide is an electronic programme guide in your TV. This function shows you the programmes of all channels and your scheduled recordings for the next few days.
The TV Guide is available in all Swisscom TV-Boxes. If you have a UHD-enabled TV-Box, you can with your remote also browse the TV Guide via the speech recognition function in addition to the manual search.
❗ | Did you know: Your TV can also understand Swiss German. We have enhanced the remote control’s speech recognition function. Now you can also search for programmes in the TV Guide in Swiss German, Italian, English and French. |
Support
Do you have questions concerning our products?
We will help you via telephone or chat.
