Call our sales hotline
Opening hours:
Set up and use
Business WLAN-Box
Get to know the device
  1. Pair button
  2. WLAN button (inactive)
  3. Power button
  4. Power
  5. Reset button
    After 7 seconds, all LEDs flash red and then white (1 - 2 x per second)  device restarts
  6. 2 LAN Ethernet connections
Power LED
Steady white The device is ready for operation.
Flashing white The device is starting, being configured or updating.
Please do not switch off.
Steady red There is a fault. Restart the device.
Status LED
Steady white WLAN is an ideal distance from the router.
Flashing white WLAN is too close to the router or the nearest WLAN-Box.
Steady red WLAN is too far away from the router or the nearest WLAN-Box.
LED not on WLAN is switched off or not paired to the router.
Pairing LED
Steady white Pairing between the router and WLAN is OK.
Flashing white
(1–2x per sec.)
Pairing is complete.
Steady red Pairing with the router cannot be restored.
FAQs
Type 192.168.1.1(opens in new tab) into your Internet browser. Please note that you will only be able to access this address if you are in the same network as the Centro Business 3.0 router. Log in with your existing admin password for your Centro Business 3.0 router. If you do not know the password, visit the Router Administration section of your My Swisscom Business(opens in new tab) (Customer Center).
You can only use the Business WLAN-Box in combination with the Centro Business 3.0.
Find out the energy consumption of your Business WLAN-Box here:
Energy consumption
The firmware on your Business WLAN-Box will be updated automatically as soon as a new version is available.
Firmware
Choose your support option
My Swisscom Icon
Manage your products, services and data directly in your account.
Open My Swisscom(opens a new window)
Swisscom Chat
The digital assistant Sam helps you with questions about your Swisscom products.
Start Chat
Get personal help from experienced Swisscom customers.
Go to help
