Ascona HD-Phone
On this page:
Install and use your Arosa HD-Phone and change the ringtone.
Installation & keypad overview
Find out everything you need to know about the operation and functions of this HD phone.
The HD-Phone Ascona only works in conjunction with the Swisscom Internet-Box on a fixed network connection (IP).
Instructions
Set up
Making calls
Managing calls
Call forwarding
Change ringtone
Your HD-Phone Ascona has a choice of 13 ringtones. You can select different ringtones for internal and external calls.
Change settings directly on your handset:
  1. Menu
  2. Note icon (= ringtones)
  3. Select external or internal calls
You can now listen to all the available ringtones and save your favourite one.
You can assign a different ringtone for every directory entry so you can recognise when a family member is calling by the ringtone, for instance.
On your handset press Menu > Directory > Add and select the required ringtone via the note icon.
