The Ethernet Switch allows you to connect up to 7 additional devices to one Ethernet port. The Ethernet Switch is compatible with all Swisscom Internet-Boxs.
How to install your Ethernet Switch:
Plug in the device and connect the Ethernet Switch to your Internet-Box using an Ethernet cable (not supplied). Use the Ethernet connection 1 to connect the Ethernet Switch and router.
Click the blue plus icon to find out more about the ports and buttons on your Ethernet Switch.
There can be connection problems if you use the Internet-Booster and WLAN-Box in tandem with the Ethernet Switch at home. If this happens, reset all the settings on your Ethernet Switch and reconfigure the device again.
Do you not have a Swisscom Ethernet switch? If not, check the manufacturer’s instructions as to whether your device supports VLAN settings and how you can adapt them. The two Ethernet ports to which Internet-Box 2/ Internet-Box 3 and the Internet-Booster are connected, must support VLAN 699, VLAN 700 and VLAN 1977.
Proceed as follows:
Support
Do you have questions concerning our products?
We will help you via telephone or chat.
