Call our sales hotline
Opening hours:
Set up and use
WLAN-Box 5
App instructions
The My Swisscom App will guide you through a step-by-step setup process for your device.
Scan the QR code to get started.
QR-Code
App instructions
Get to know the device
  1. + button
  2. Status LED 
  3. Reset
  4. On/Off (Power)
  5. Ethernet 1 Gbit/s  (2x)
  6. Ethernet 10 Gbit/s  
  7. Power supply port  
Steady white LED: Everything OK.
Flashing white LED:
  • Pairing in progress. Please wait for two minutes.
  • Swisscom configuration update in progress. Please wait for five minutes.
Pulsing white LED: WLAN schedule is active on the Internet-Box.
The WLAN-Box 5 is not currently transmitting WLAN.
Flashing red LED: No connection to the Internet-Box. Either the WLAN-Box 5
is not paired or it is too far away from the Internet-Box.
Pulsing red LED: Weak connection to the Internet-Box. Place the
WLAN box 5 closer to the Internet box and as free-standing
as possible.
Steady red LED: No connection to the Internet-Box or error.
  1. Your WLAN-Box may still be starting up.
    Please wait 2 minutes.
  2. Pair.
  3. If the LED lights up red again,
    please restart the Internet-Box and the WLAN-Box 5 Pro,
    then repeat the pairing process.
Steady blue LED: Defective WLAN-Box 5. Please contact Swisscom for a replacement.
Please note that the LED temporarily lights up blue
during the start-up process. Wait five minutes until the process is complete.
Frequently asked questions
Wi-Fi 7 is the latest Wi-Fi standard for the technology of the future. Alongside the 2.4 and 5 GHz bands, which have been available for several years, tri-band Wi-Fi also has a 6 GHz band. This band is low interference, because there are currently fewer devices in this range.
The WLAN-Box 5 Pro is compatible with all WLAN devices, regardless of their Wi-Fi standard.
Installation of WLAN-Box 5 Pro without the My Swisscom app
  1. Select the optimal location for your WLAN-Box – as centrally as possible between the Internet-Box and the room in which you want to improve the WLAN.
  2. Connect the WLAN-Box to the power and switch it on.
  3. As soon as the LED on the WLAN-Box flashes red, press the plus button (+) on the WLAN-Box and then the plus button (+) on the Internet-Box. Do this within two minutes.
  4. If the WLAN-Box 5 Pro LED shows a steady white light, the devices have been successfully paired.
  1. Place the WLAN-Box in the room in which you want to improve the WLAN.
  2. Connect the WLAN-Box directly to the Internet-Box using the Ethernet cable supplied.
  3. Connect the WLAN-Box to the mains power and switch it on.
Change the WLAN-Box 5 Pro settings through the Internet-Box web portal. This is where you can change your WLAN access data, configure parental controls (surf times and time limits) or display all the connected devices.
On computers
Enter http://internetbox.swisscom.ch(opens in new tab) or 192.168.1.1(opens in new tab) in your Internet browser. Note that you have access only if you are connected to your Internet Box within the network. Log in with your existing admin password. If you do not know the password, click on "Set new password" to create a new password.
On smartphones
You can access and change your main settings at home on your smartphone via the My Swisscom app.
The WLAN-Box 5 Pro is compatible with the Internet-Box 2 and all more recent models. The Internet-Box plus and Internet-Box standard support the older WLAN standard (Wi-Fi 5) and are unable to reach the maximum WLAN speed of the WLAN-Box 3. In addition, these routers do not support the latest encryption standards, which can lead to incompatibilities with the WLAN-Box 5 Pro For these reasons, the Internet-Box plus and Internet-Box standard are not compatible with the WLAN-Box 5 Pro.
To use Wi-Fi 7 with the WLAN-Box 5 Pro, WPA3 encryption is required.
To ensure optimum WLAN-Box 5 Pro function, WPA3 is automatically activated on the router during the installation process.
Some older devices, such as WLAN printers, do not support this new standard and can therefore no longer connect to the WLAN.
To connect your device (e.g. a printer) to the WLAN-Box 5 Pro, manually reset the WLAN encryption to WPA2.
For the interference-free 6 GHz WLAN band, the WLAN-Box 5 Pro has four more antennas than the WLAN-Box 5.
These require more space in the casing.
The larger design also has a positive effect on the generation of heat in the device.
Check this in the WLAN tab in the web portal. Here you will see whether WLAN and the 6 GHz band have been activated.
The device to which the WLAN-Box 5 Pro is connected must also support 6 GHz and the latest WLAN standard (Wi-Fi 7 or Wi-Fi 6E)
If you use two WLAN-Box 5 Pros or one WLAN-Box 5 Pro and one WLAN-Box 3, you can connect these to a WLAN mesh via the 6 GHz band,
reducing the strain on the 2.4 and 5 GHz bands. Devices that do not support the 6 GHz band also benefit from a better connection.
The maximum WLAN transmit power of the WLAN-Box 5 Pro is limited to 1 Watt per band and the device complies with all relevant regulatory limits and guidelines. To minimize radiation, the WLAN-Box 5 Pro can also be switched off manually. In addition, the WLAN operating time settings from the Internet-Box are transferred automatically to the connected WLAN-Boxes.
To ensure your device will use Wi-Fi 7 to connect to the WLAN-Box 5 Pro instead of the Wi-Fi 5 or 6 of Internet-Box 2, 3 or 4, do the following:
  • Connect the WLAN-Box 5 Pro to the Internet-Box with an Ethernet cable (WLAN Access Point).
  • Deactivate the “Synchronise WLAN status between the Internet-Box and WLAN-Box” option in the web portal.
  • Switch off the WLAN on the Internet-Box.
Yes, the guest WLAN works in the Internet-Box WLAN and in the WLAN-Box 5 Pro reception range.
Discover the electrical energy consumption of your WLAN-Box 5 Pro here:
Energy consumption
Check out these tips and discover how to save energy:
Tips on saving energy
Your router’s firmware will update automatically as soon as a new version is available.
Firmware informations
If your WLAN-Box is experiencing issues and a restart doesn't solve them, the device can be reset to factory settings. Here's how to perform a reset on your WLAN-Box:
  1. Plug in the WLAN-Box and turn it on. Then, wait 2 minutes for the WLAN-Box to start up.
  2. Perform the reset using the method shown in the image below by pressing the reset button on the underside of the device with a pointed object for 1 second.
  3. After a successful reset, the status LED will start to blink white, and the WLAN-Box will restart.
After the reset, the device can be reinstalled using the My Swisscom App.
Choose your support option
My Swisscom Icon
Manage your products, services and data directly in your account.
Open My Swisscom(opens a new window)
Swisscom Chat
The digital assistant Sam helps you with questions about your Swisscom products.
Start Chat
Get personal help from experienced Swisscom customers.
Go to help
