HD-Phone Gigaset E560HX
Your HD phone Gigaset E560HX
Installation and keypad overview
Find out everything you need to know about the operation and functions of this HD phone.
The Gigaset E560HX HD-Phone only works in conjunction with the Swisscom Internet-Box on a fixed network connection (IP).
Declaration of conformity
Download here the PDF version.
Set up
Making calls
Managing calls
Call forwarding etc.
You can configure settings directly on your handset to forward calls or reject calls you do not wish to take. Proceed as follows:
Network services
Scroll down and set up service (call forwarding, reject unknown calls etc.) > OK
The following Swisscom services are available:
Do not disturb
Block anonymous calls
Call barring
Divert incoming calls to another telephone number
Divert all incoming calls to a message
Divert all calls with suppressed telephone number to a message
Enter the telephone number of the last call in a black list. Calls with this telephone number are no longer diverted to the handset.
